Can't start SH3D on Macos Yosemite
I tried the version with home brew and directly from the Website.
unfortunately SH3D wount start.
here ist one error I see when starting from console ./SweetHome3D [JavaAppLauncher] Requested [1.5*], launching in [1.8] instead. Java 3D: implicit antialiasing enabled Exception in thread "J3D-Renderer-1" java.lang.UnsatisfiedLinkError: no jogl in java.library.path at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1864) at java.lang.Runtime.loadLibrary0(Runtime.java:870) at java.lang.System.loadLibrary(System.java:1122) at com.sun.opengl.impl.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:189) at com.sun.opengl.impl.NativeLibLoader.access$000(NativeLibLoader.java:49) at com.sun.opengl.impl.NativeLibLoader$DefaultAction.loadLibrary(NativeLibLoader.java:80) at com.sun.opengl.impl.NativeLibLoader.loadLibrary(NativeLibLoader.java:103) at com.sun.opengl.impl.NativeLibLoader.access$200(NativeLibLoader.java:49) at com.sun.opengl.impl.NativeLibLoader$1.run(NativeLibLoader.java:111) at java.security.AccessController.doPrivileged(Native Method) at com.sun.opengl.impl.NativeLibLoader.loadCore(NativeLibLoader.java:109) at com.sun.opengl.impl.macosx.MacOSXGLDrawableFactory.<clinit>(MacOSXGLDrawableFactory.java:53) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:264) at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:108) at javax.media.j3d.JoglPipeline$QueryCanvas.<init>(JoglPipeline.java:9029) at javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8793) at javax.media.j3d.Renderer.doWork(Renderer.java:514) at javax.media.j3d.J3dThread.run(J3dThread.java:275)
Re: Can't start SH3D on Macos Yosemite
You should install Apple Java 6 or run the Java Web Start version (once you clicked on the previous link, click on the SweetHome3D.jnlp downloaded file while maintaining the ctrl key pressed, and choose Open in the contextual menu that will appear).
