Total posts in this thread: 27
Posts: 27   Pages: 3   [ 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 34528 times and has 26 replies Next Thread
enkonyito
Comparative global illumination
By default, Sweet Home 3D uses global illumination "ambient occlusion".
Indirect light reflected by objects can be simulated by setting global illumination to "path".
The rendering will be longer.
EnkoNyito
[Nov 17, 2015, 4:50:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: Comparative global illumination
Where do you change this setting?
Hawk
[Nov 17, 2015, 7:10:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
By using this plug-in .
More info about it here .
EnkoNyito
[Nov 18, 2015, 12:02:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Thanks. I have that plugin installed. I know what you're talking about now.
Must have been a senior moment that it didn't dawn on me. laughing
Hawk
[Nov 18, 2015, 1:34:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Recently, I upgraded my PC, so it's much faster now. Therefore I decided to play around with this photo plug-in. Unfortunately, I can't figure out how it works.
Am I correct in thinking that this plug-in has effect only when making a render in Q4?
[Nov 18, 2015, 3:34:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
I believe it works in Q3 and Q4.
Hawk
[Nov 18, 2015, 3:40:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Hans, Hawk,
Version 1.2 of the plug-in incorporates some additional information like an illustration quality levels and a small parameters definition.
Hans:
Hawk:
It is used as a SweetHome3D.l4j.ini file, a Linux launch script or Jar command lines to change the photo renderer properties at the two best quality levels (Low/Q3 and High/Q4).
Hans:
I should perhaps make a tutorial like plug-ins and extensions User Guide .
Regarding global illumination "path" , a sky with texture can give a rendering dark, powerful lights can give a dazzling rendering.
Enko
EnkoNyito
[Nov 18, 2015, 7:18:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
That's the one I have. smile
Hawk
[Nov 19, 2015, 6:59:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
A tutorial explaining the use of the plug-in is available here .
EnkoNyito
[Jan 15, 2016, 3:47:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
santbose
India
Hi Enkonyito,
I have downloaded the plugin 1.3 and using the portable version of SH3D 5.1. But am not able to select the filters and Sampler Algorithm. Neither the option Create photo with advanced render properties is working. Can you please help me and guide me how to use the plugin. I am doing a large scale project for my client.
[Jan 15, 2016, 5:11:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
