Posts: 16   Pages: 2   [ Previous Page | 1 2 ]
Previous Thread This topic has been viewed 19725 times and has 15 replies Next Thread
Re: Toggle visibility INSIDE grouped items
I don't think I have fully grasped all the subtleties of the comment hierarchy here yet. My intention was to comment upon mazoolas reply to me, but for some reason I can't get my comments to be addressed to the right person.
Well...
[Feb 21, 2016, 10:46:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
@Cecilia
This comment is for you.
@okh
And guess who this is adressed to.
[Feb 21, 2016, 11:16:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
@Ceciliabr
I have so far never seen any trace of an object after applying this texture to it.
Nor have I seen a 'visible invisible' texture after applying a fully transparent PNG as a material -- but some folks have. My guess is, as OK said, it has to do with SunFlow's handling of surfaces -- which, my recent experiments suggest,* is a surprisingly complicated topic.
My suspicion, though, is that it has less to do with calculation of surface normals than with glossiness; that is, I suspect a glossy invisible surface, besides being an oxymoron, would be more likely to display artifacts than a matte invisible surface. Applying an invisible texture to an entire object might also lead to different results than applying the same texture to individual components of the object.
All this is pure speculation, though, as I've not tested my hypotheses -- something I'll no doubt do the next time I have something far more important to put off doing. wink
Maz
__________
* I should note in passing it was your recent post that sent me down that particular rabbit hole. While for most of my life I made my living as a technologist of some stripe -- and even once contributed about half the pages to a book on programming in Pascal, available in English and German wherever painfully obsolete computer texts are found -- I'm actually an English baccalaureate whose last math or science class was in high school; I'm definitely, as the idiom has it, 'punching above my weight.'
[Feb 22, 2016, 8:02:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@hansmex
Of course... writing the address. Why didn't I think of that?
And the "quick reply"- button must be for people with great haste – but you still have to write the address – right?
I think I've got it now... :)
[Feb 22, 2016, 12:01:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bilfrost
United States
Hi y'all. I know I am replying to an ancient thread here.... but have been struggling with this visibility issue for a while.
My particular situation:
- I have various objects grouped together for logical reasons (eg. a stack of kitchen cabinets)
- I want to make a change to a bottom cabinet. On my outline, I cannot access it. Of course, I can select the piece of furniture in the list and manually enter the things i want to change about it; but I cannot see these changes
- my workaround has been to ungroup the items, hide the top pieces until the one I want to work on is visible, make the changes, and then group everything back up together.
It seems like this would be much easier if I could just hide things within a group.
[Aug 16, 2021, 5:03:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hecatoncheir
Basically necroing this just like Bilfrost did last year, but I'm also a bit puzzled by how to work effectively with this limitation.
Am I right in saying that the reason it's complex is that grouping isn't just a way to organise the object list but it's also affecting placement rules when moving things about? And I guess that's the same reason we appear to be limited in how many levels we can have?
Is there a better way to organise a hierarchy of objects by levels and rooms then that makes up for this? Like Bilfrost I'm often dragging stuff out of the group it belongs to in order to toggle visibility now.
[Aug 1, 2022, 3:44:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
