Previous Thread This topic has been viewed 5535 times and has 9 replies Next Thread
hobbyrv
shelves become squares
When I import a wooden texture for a floor, I want to have long shlves.But every texture I try makes squares of it. See for example:
How do I make long shelves?
[Nov 23, 2015, 12:05:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
swave
Re: shelves become squares
Create a picture in the dimensions you want. Upon importing you can specify the size. With this you can also create non-square textures.
[Nov 24, 2015, 3:16:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
There's also some really nice wood textures in the Textures-Contributions-1.1.zip that don't come out squared, found at this link:
http://www.sweethome3d.com/importTextures.jsp
Hawk
[Nov 24, 2015, 4:25:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Thank you for your reply. But I've already did that. But when I change the measures, I can’t change both the heigth and width seperately. When I change one, the other changes automatically in the same ratio. So the squares stay, only bigger.
[Nov 24, 2015, 7:40:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Thank you for your reply hawkdawg. But I've already did that earlier, so that is not the cause. See also my former reply to the reaction of swave.
[Nov 24, 2015, 7:43:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
Additionally: the squares only appear when I import floors from the other websites mentioned underneath on the texture import page. So my next question is now: are there more options for wooden floors (and perhaps also other materials) that can be imported as shelves. Because I need a whitewash wooden floor for my current design.
[Nov 24, 2015, 8:22:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Good seamless textures are necessary, if not they will inevitably appear as rectangular patterns. But how the pattern stretches also depends on texture mapping on the original object or how the wall / floor is aligned in the plan, see for instance thread 5533: Floor Texture - Adjusting Problem. ok
[Nov 24, 2015, 9:01:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
swave
That's why I said you need to create the picture already in the needed dimensions or ratio. If you need a 1:4 pattern make it e.g. 100x400 pixels. On importing you can say 400pixels is 1 meter.
[Nov 27, 2015, 8:40:34 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
hobbyrv
thank you all
[Nov 27, 2015, 11:25:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
I don't know if you'd be interested in this, but there's a small utility called Tile Viewer that let's you see what images look like when they're tiled.
Using tile-able textures goes a long way to avoiding that blocked look.
You can find Tile Viewer at AmpSoft .
Hawk
[Nov 28, 2015, 8:50:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
