Miscellaneous Box - Textures don't tile?
This topic has been viewed 8744 times and has 1 replies
Thread status: Active
Looking for a particular 3D model or texture? [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
User avatar
digitaltrails
Country: Wellington, New Zealand, New Zealand
Contact:
Post by digitaltrails »
The Miscellaneous Box furniture item doesn't behave as I would expect.
If I apply a texture to a whole box, when the box is resized, the texture size remains constant and the texture tiles. This is what I expect. For example, for a box of floor-boards, the floor-boards remain the same size, when the size of the box changes, they tile so the box appears to have more boards.
If I apply the same texture as the Material for one side, when the box is resized, the texture scales instead of tiling. For example, for a side covered with floor-boards, when the box size changes, the box always has the same number of boards, the boards increase/decrease in size. This can be useful, but it is not what I expected.
Is there a problem with Miscellaneous Box, or is it a deliberate feature? In which case it would be great to have two Miscellaneous Boxes that allow for both options.
I've built my own box obj model which behaves as I expected (if anyone's interested I can post the obj text here, it's not very big).
While we are on the subject of a generic shapes, it would be great if the distributed set of objects included a generic wedge, and generic pipe (cylinder on its side).
User avatar
HawkDawg
Country: Georgia, USA
Contact:
Re: Miscellaneous Box - Textures don't tile?
Post by HawkDawg »
Depending on what you're trying to accomplish, I find using walls a better option as they texture a lot better than models.
As I mentioned in this post , I used a wall to build a slope for the swimming pool instead of a triangle because the triangle textured a bit skewed diagonally.
I would be interested in the box you made.
Hawk
Who is online
Users browsing this forum: MSN [Bot]
