Total posts in this thread: 2
Previous Thread This topic has been viewed 4283 times and has 1 reply Next Thread
LillyDu
STRG+E don't work anymore?
I used the program for some weeks and all worked fine (I use Ubuntu).
I installed the latest version from the SweetHome3D homepage.
But since yesterday, I can't change the attributes neither for walls nor for furnitures.
Also I can use drag and drop from the left menu. I can only add furnitures to the plan via the menu.
Did I set a change somewhere?
Do you have an idea?
Thank you in advance for your ideas.
[Jan 1, 2016, 12:40:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: STRG+E don't work anymore?
You probably thought of this, but you may have locked the plan (the small padlock in top left plan corner)? But that should not affect all furniture, only the base plane ones, so that may not be it. ok
[Jan 2, 2016, 9:40:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
