Features
Posts: 44   Pages: 5   [ Previous Page | 1 2 3 4 5 ]
Previous Thread This topic has been viewed 94463 times and has 43 replies Next Thread
mazoola
Re: Sweet Home 3D 5.2
Emmanuel -
I recently installed versions 4.6, 5.1, and 5.2a simultaneously to compare render quality and handling of Sketchup two-sided faces -- but I'm not here to talk about that. Instead, I swear it seems as if images render faster using a bucket size of 64 than one of 32 -- even though I can't think of any reason that would actually be the case. (I'm sure it is slightly faster, simply from having to do only half as many bucket set-ups and tear-downs, but I can't imagine the difference would be perceivable.) Instead, I have to assume it's simply an illusion -- but it's a welcome illusion.
Thanks,
maz
[Mar 5, 2016 3:18:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I updated the bucket size to 64 because I read it was a good default value. Actually, I hope it's better than 32, not only for the speed. wink
By the way, about the problems you reported when you updated to version 5.2:
When using the click-and-drag method of changing Virtual Visitor eye height in the 2D window, the Visitor icon shrinks as it is lowered
There was no change in this behavior (for reasonable height values, the visitor size is supposed to match the size of the human with the eyes at the same elevation as the camera), but I know I should find a better solution. Actually the indicators at the border of the visitor have an higher priority when the mouse pointer is placed on them, making the center zone used to move the visitor too small in some cases.
The 3D window (in Virtual Visitor mode, at least; I haven't tested it in Aerial View) often fails to update or takes an inordinately long time to update.
Maybe you unchecked the Adjust eyes elevation according to selected level option available in the virtual visitor modification pane when there's more than a level in a home?
after I open the furniture properties window, especially for a complex model, when I go to close it SH3D often takes an unusually long amount of time to do so -- even if no changes have been made.
Did you notice it was longer than with previous versions? Maybe the home you design becomes quite large, and as you're under a 32 bit system, it won't be possible to use much more RAM for the program.
[Mar 5, 2016 10:24:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
mazoola
Emmanuel --
Please see this post; I fear I didn't make it clear enough what I was referring to. After testing and documenting those three consistently repeatable errors, I rebooted -- and they all went away. I suspect it was a conflict between versions when installing one on top of the other.
Many (but not all) of the render oddities disappeared after the reboot, as well.
maz
[Mar 5, 2016 11:27:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mazoola
@Emmanuel -
While the extreme delays in updating the 3D window or to return from editing an object have not recurred, I have experienced the Incredible Shrinking Virtual Visitor again under 5.2a. Unfortunately, I still haven't identified the sequence of actions required to enter that state (or to leave it, for that matter). The symptom is the same as initially reported: Using the click-and-drag method to lower or raise Visitor eye height causes the Visitor icon to shrink or grow, respectively.
maz
[Mar 9, 2016 7:58:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
