Previous Thread This topic has been viewed 7428 times and has 2 replies Next Thread
bartleby
how to connect walls?
if u want to make a corner (90 degrees) out of 2 single walls, after changing a plan, those 2 walls will not be perfectly connected like when u build this corner at once.
is there a way to fix this?
sometimes tricky in the 3d-view.
maybe i should add a picture if am at home ;).
[Jan 19, 2016, 8:55:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: how to connect walls?
If you do not want to draw the wall again so it joins existing walls, the Advanced plan editing plug-in will let you join (connect) walls. Pay attention to wall direction (reverse if need be) and the order you select the walls you wish to connect. ok
[Jan 19, 2016, 3:16:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bartleby
again, thx. great program and that for free - must be really much work.
i had problems with my houseproject being too big. with windows 7 i can make pictures in every quality without a problem, but with linux mint i have no chance to make pictures with better or best quality. worked in the beginning when project was smaller. maybe it will work again with ure "connect wall fix" - we will see.
[Jan 19, 2016, 7:01:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
