Re: Progress and time of photo rendering (Create photo with renderer plug-in)
Santbose,
As said Mazoola, Sunflow uses different types of light for a sky without texture (SunSkyLight) and a sky with texture (ImageBasedLight). Although they have a parameter that seems common, rendering for a sky with texture depends on the image used (example: blue sky or cloudy sky).
Poland
enkonyito, Your plug-in is great but I encountered some issues.
1) When "Apply proportions" is set to "3d view", changing image width to any value always makes height = 2,147,483,647; new height value makes width = 0. Switching back from "Square", "4/3" and other proportions presets (that work fine) also causes this unwanted effect. If I want my image to keep proportions of 3d view but I need to change size I have to do it via standard "Create photo" window.
2) "Create photo with renderer" window doesn't fit to my screen height(1024x600px) - I don't see "Create", "Save" and "Close" buttons, even if I move or hide task bar. I use Tab key but I have to carefully count hits to avoid accidental skipping "Save" button when I'm finally satisfied with my image.
alax,
I can not reproduce it even by displaying the 3D view in a separate window. Is this occasional or systematic? Have others met the same kind of problem?
This will be fixed in the next version of the plugin that will be soon available.
EnkoNyito
Poland
Thanks for reply.
- With 3D view docked (in main window) everything works fine. - When I open "CPwR" first and then detach 3D view - it also works fine. - Problem occurs every time I open "CPwR" when 3D view window is already floating(in my case - almost all the time). What I forgot to mention in my previous post - resizing this floating 3D view window manually(dragging edges) makes no changes to width and height fields in "CPwR".
Apparently, only me and I have met this problem - it happens on my both laptops - WinXP and Win7(32-bit).
By following your procedure, I was able to test the bug and find a solution.
EnkoNyito
