Previous Thread This topic has been viewed 4001 times and has 2 replies Next Thread
vsilver17
Dark room when disabling artificial light
Hello everybody! My problem is that when i disable artificial light the sunlight is not enough and the room is almost totally dark. The strange thing is that the room is south exposed and i set 10 July at 13:00 so I think it should be totally enlightened.
Can someone help me find a solution if there is any?
[Feb 8, 2016, 7:22:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
anhmax
Re: Dark room when disabling artificial light
You should try this: put 3 or 4 white light sources, size 0,6 - 0,8m, power 10-20%, elevate them a half of your room height, turn off ceilling light. Set 9-10am and let the sun through window. Good luck.
If you still have no idea, send me your sh3d file, I will help you.
My channel:
[Feb 9, 2016, 6:40:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please see also this thread and this one.
[Feb 10, 2016, 1:43:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
