germany
Re: Landscaping
Hallo everyone,
I am trying to create a realistic Landscaping around my project. The challenge is:
1)The terrain around the house has multiple vertical angles in various directions. 2)The boundaries of the property have a polyline layout. And I need to stay within these horzontal boundaies.
I tried to build with geo triangles. It is getting way to complex. In order to complete the task I figured I simply need a geo shape that allows two different angles in a rectangle horizontal shape. (variable heights from ground for each corner A;B;C;D of that rectangle).
Re: Landscaping
If all the surfaces are vertical or horizontal you may be able to produce them with the shape generator plug in, any curved surfaces would need other software as Hans suggests. Mike
germany
Re: Landscaping
I tried the plugin. It is not very comfortable to use, as it does not support drag and drop (much trial and error), but you get used to it - and does exactly what I needed. Thanks for the Tip!
I also installed blender, but for now it seems to be a bit to complex, I will familiarize with it later.
