Previous Thread This topic has been viewed 3515 times and has 2 replies Next Thread
enkonyito
Inability to install Sweet Home 3D 5.2 on Windows Vista
When I do right click "Run as administrator" on SweetHome3D-5.2-windows.exe, nothing happens.
So I can not use the SweetHome3D.l4j.ini file.
With SweetHome3D-5.1-windows.exe, the installation window opens.
EnkoNyito
[Feb 20, 2016, 4:13:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Inability to install Sweet Home 3D 5.2 on Windows Vista
I hope you'll find the reason why it doesn't work for you, just because I don't have any PC with Vista to test the installer. I tested it on Windows XP, 8.1 and 10.
But why do you need to run the installer with Run as administrator menu item?
[Feb 20, 2016, 5:02:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Double-clicking does not work, I tested the right click...
I have not had any problems with the beta versions of the installer.
The SweetHome3D.l4j.ini file was useful to set preference the rendering properties. As I use the portable version instead, I should find another solution.
EnkoNyito
[Feb 21, 2016, 11:00:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
