Previous Thread This topic has been viewed 3942 times and has 2 replies Next Thread
Shaggy1
AdvancedEditingPlugin - Edit room plan dialog blank
Hi
I am using sweethome3d on fedora 20. I have installed the AdvancedEditingPlugin by copying AdvancedEditing.sh3p to ~/AdvancedEditing.sh3p
However when I select Plan->Edit room plan ...
The resulting dialog is blank. When I click the mouse on it bits of the dialog appear.
Anyone any idea why this might be happening and how I might go about fixing it ?
The native java I have installed (if it is relevant) is java-1.7.0-openjdk.
I did find a thread which seems to be a similar problem here:
http://www.sweethome3d.com/support/forum/view...965B88AF8F16416A9E9CA5164
but I could not determine what the solution might be from this.
[Feb 26, 2016, 8:22:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: AdvancedEditingPlugin - Edit room plan dialog blank
Did you try with the version available at Download page? It comes with an older version of Java so that might make some difference.
[Mar 15, 2016, 7:48:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Shaggy1
Hi
Finally had a chance to have a look at this.
I re-visited the initial thread I found and realised it does indeed give the solution to the problem. Clearly I did not read it properly the first time.
It seems sweethome3d comes with and uses a local version of jre (for some reason I thought it used the systems version). The plugin does not work with the version sweethome3d comes with (jre1.6.0_45).
As mentioned in that thread downloading a later version of jre (I downloaded jre1.8.0_77), installing it in the SweetHome3D-x.y directory and setting jre1.6.0_45 to point to that version fixes the problem.
Does anyone know how I can find out where sweehome3d decides where it gets jrel from ? Can this be specified using env variables or is hard coded in the source somewhere ?
[Mar 28, 2016, 10:35:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
