Total posts in this thread: 35
Posts: 35   Pages: 4   [ Previous Page | 1 2 3 4 ]
Previous Thread This topic has been viewed 110576 times and has 34 replies Next Thread
Re: Shape Generator plug-in
Here's the version 1.2 of ShapeGenerator plug-in which provides an additional view of the 3D model from entered coordinates, when you select the new 3D preview radio button.
Many thanks to Dorin who programmed this change! smile
[Nov 21, 2020, 9:53:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Ah! Good news, very useful. Thanks both of you.
[Nov 21, 2020, 12:54:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
I want to show some tips:
1. Triangular prism
Some explanation:
-On Shape Generator set to pair of points at same coordinate.
In this case I chose 5+8 and 6+7.
-In plan, select the generated shape and open Modify furniture - modify materials.
- As You see in second image there are 5 sides in place of 6
2. Pyramid
-Same procedure but for 4 upper points.
3. Roof part
-Make more and combine in plan.
-I recommend to apply texture AFTER resize the shape (if you need to resize)
And this could be this sample
Hope to be useful to somebody.
PS. Don't believe Emmanuel entirely; He write all codes, I have only the idea and garbage of useless file.
[Nov 21, 2020, 7:17:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Thanks for the examples. Finally I may give it a try myself 😜
[Nov 21, 2020, 7:48:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
So do I.
[Nov 21, 2020, 9:34:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2021 eTeks - All rights reserved
