Total posts in this thread: 2
Previous Thread This topic has been viewed 3334 times and has 1 reply Next Thread
nzr
The problem can't be solved
The design of the shopping center.
The windshield not be seen
Glass is not clear ؟؟؟ Where is the problem ؟؟؟؟؟؟؟
As well as the non-appearance of wall color (white)
I dont know how do I work the door glass ؟؟؟؟؟؟
thanks
[Mar 6, 2016, 9:07:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: The problem can't be solved
Design looks nice...
Glass is not clear ... Where is the problem....
The glass transparency depends on the model you use. Transparency could be either by a semi-transparent texture (which can be changed), or a model with transparent surface. You could try other models like some found in the Libraries of 3D models, especially the new models in 3DModels-Contributions-1.6.1.zip. - you can also find the individual window models in the Free 3D models:window - but remember to import them as Door/window.
If the transparency is not a texture, but a transparent surface in the model, it is possible to export the window to .obj and edit the transparency in the .mtl file - not entirely straightforward, but some threads (like 5056) might help you if you want to try.
As for white colour, I am not sure what you mean. But white will never render as 100% white, as that would not create a life-like rendering.
[Mar 6, 2016, 10:42:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
