Features
Total posts in this thread: 7
Previous Thread This topic has been viewed 5815 times and has 6 replies Next Thread
hansveldt
3D error WIN10
Installed sweethome3d 5.2 on WIN10. Installation seems ok. After starting, the program shows up but an error "3D error" (or 3D fout in Dutch) appears.
[Mar 6, 2016 5:19:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Albino6
Re: 3D error WIN10
I have the same problem. I started the program with Java webstart.
Win 7 64 bit
Intel Xeon
Is there also a portable version of 5.2
[Mar 7, 2016 7:38:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Rudie
Re: 3D error WIN10
Sama problem here
Also in the Dutch version....
[Apr 5, 2016 8:56:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
deberkjes
Re: 3D error WIN10
Also I have the same problem. version 5.2
Installation went well but received the note that my DirectX is not the right version. Have Windows 10 and Dirext X 11.1. Have tried Windows update but they gave the message all is at the latest versions. Please advice what to do.
Version 5.0 on an computer works well.
[Apr 19, 2016 8:46:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D error WIN10
Please try the version 5.3 Beta 6 which should fix this issue. As this Beta version doesn't contain any new feature yet, you can continue to use it without risk until the final version 5.3.
[May 20, 2016 6:53:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
leon42
Re: 3D error WIN10
Very Strange problem !
I installed SH3D on my surface4 , it works perfectly for a couple of time , execpt tiny icons and menus . I found the solution in the threads But before having tried this solutions SH3D doesn't start anymore ? I tried the 5.3 java web start . SH3D starts and stops (direct X Problems ) I'm very disappointed , I need to use and old computer to be able to launch SH3D
A tablet or surface is very useful to have your drawing anywhere on the workshop
Thanks in advance for your help
[Aug 29, 2016 7:09:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
leon42
Re: 3D error WIN10
I finally found the solution
It is due to the windows update The latest version probably a beta one of windows has been installed . I reinstall the win 10 previous version and right now SH3D works perfectly on my surface 4 with the 5.3 beta and HiDPI parameter
Greattttttttttttttttttt !
[Aug 31, 2016 4:37:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
