Previous Thread This topic has been viewed 5877 times and has 2 replies Next Thread
enkonyito
How to rebuild Sunflow for Sweet Home 3D?
As indicated in Sunflow wiki page 57, you can change the value of groundExtendSky in SunSkyLight.java file then recompile Sunflow for it to take effect.
groundExtendSky = false
groundExtendSky = true
Following the directions in the README.TXT file of sunflow-0.07.3i-src-diff folder in Sweet Home 3D source code, a sunflow-0.07.3i.jar file is created in the release folder of Sunflow source code.
Is this the right method to rebuild Sunflow for Sweet Home 3D?
EnkoNyito
[Apr 3, 2016, 4:58:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to rebuild Sunflow for Sweet Home 3D?
You can use the default way provided by SunfFlow too, and rename Sunflow jar file afterwards.
It's just the way proposed in the provided build.xml creates a smaller Jar excluding useless classes.
[Apr 3, 2016, 2:22:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The other method works by pasting modified files for Sweet Home 3D in Sunflow directory.
In SH3D, differences are visible in the rising or setting sun.
groundExtendSky false_samples 0
groundExtendSky true_samples 0
groundExtendSky false_samples 16
groundExtendSky true_samples 16
EnkoNyito
[Apr 6, 2016, 1:50:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
