Hi I've just installed SW3D on my MacBook Pro (10.10.5 Yosemite), it start but stay on the logo (which does not disapear...) The menu appears with only one feature "Sweet Home 3D" I've updated java and resatrted the computer but still. I've installed on my MacMini at home and it works perfectly !! Any idea? Thanks in advance,
Re: SH3D does not start
Could you try to install Java 8 and run the Java Web Start version?
Hi Emmanuel Thank you for your answer It works fine with J8 & JWS version. However it is very 'heavy' in term of CPU: my MBP is always running 100%... Thus it is not very smart & convenient... Why the initial version does not work? Is it possible to make it run? M.
If I knew, I would have told you... Is the CPU really running at 100% all the time, as soon as you launch Sweet Home 3D?
Actually it runs when I use it (not 100% but 40 to 50%, enough to make the ventilation running 100%! ;) But enough to make it not very pleasant on the MBP. However on the Mac Mini it is very nice!
Thanks anyway for this software it is very easy to handle & use, and efficient!
