Files in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D
I have been through various versions of SH3D on my system. Most recently, I have had to use the webstart version after my video card died and was replaced with one that didn't support the installed version.
While investigating a c: drive disk full problem, I noticed I have over 18 GB of stuff in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D. It all appears to be old, but I don't want to cause any problems with my setup.
Re: Files in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D
This folder contains preferences, imported 3D models and textures, and temporary files. If you remove it, you'll lose imported data in Sweet Home 3D furniture and textures catalog. But you can remove the work and recovery subfolders without problem (it's probably them who take a lot of room).
