Total posts in this thread: 2
Previous Thread This topic has been viewed 4711 times and has 1 reply Next Thread
adlerhn
Europe
SweetHome3D.l4j.ini in Linux
For increasing the max memory, as well as HiDPI adjustments (http://www.sweethome3d.com/support/forum/viewthread_thread,5384_offset,10), Linux users are asked to modify the startup script, which is understandable.
However, this script is part of the installed files, which should not be modified after install, and which will be lost after the next upgrade.
Would it be possible to configure these flags somewhere else, such as in a SweetHome3D.l4j.ini file under ~/.eteks ?
[Jul 6, 2016, 11:17:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: SweetHome3D.l4j.ini in Linux
This .ini file is a feature of launch4j which is used only under Windows.
So this might be possible under other systems but it would require some development...
[Jul 6, 2016, 10:29:25 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
