Total posts in this thread: 19
Posts: 19   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 11349 times and has 18 replies Next Thread
Latest Doodle
Hiya.
Here are few images of another property i have been working on.
Front
Lowest level
Ground floor
1st floor
2nd
and with the roof on
Be nice to hear your ideas and opinions. smile
I plan to let this one partially furnished. wink
[Jul 9, 2016, 7:15:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
why you call it doodle man? architecture looks good. love that stairs and round windows...
[Jul 9, 2016, 10:04:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HawkDawg
Re: Latest Doodle
I really like that spiral staircase myself. Nice work on that monster 'doodle'. biggrin
Hawk
[Jul 10, 2016, 5:11:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
Re: Latest Doodle
Good job !
I made a similar model with a central circular lift and staircase around smile
[Edit 1 times, last edit by bdfd at Jul 10, 2016, 8:07:09 AM]
[Jul 10, 2016, 8:06:43 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
Thx for the positive comments, appreciate them. Martin,the "doodle" comment was a little joke referring to a comment on another design.
Thought i would share a couple of detailed images of the stairs as its design is central to the project. it too houses a lift bdfd, great minds eh. smile
ground floor
1st floor
and 2nd
[Jul 10, 2016, 8:23:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
Hope that 'doodle' was joke only biggrin .... But I was not sure... wink ..... reeeespeeeect to you all of you guys smile
[Jul 10, 2016, 8:46:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
smile Re: Latest Doodle
Hi Miker777,
I am very interested in the semicircular Windows for a next project.
Where did you find them ?
[Edit 1 times, last edit by bdfd at Jul 10, 2016, 10:48:55 AM]
[Jul 10, 2016, 10:48:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
Hi bdfd.
Those are semi circular walls treated the same way as swimming pool water.Thx to Emmanuel Puybaret for that one.
[Jul 10, 2016, 2:58:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
So, heres the thing.
I had an idea, beginning to wish i hadn't, this is the semi circular roof above the lift/stairs
the idea was, this roof should also be clear, and this is what i came up with, not perfect, but i like the look.
At this point it started going down hill. i put the main roof back on
So after several hrs work creating the glass dome it was ruined by the roof.
So i opened a new plan, recreated the walls and floor put a semi circlar stair in a measured (guessed) position, exported- imported- changed thickness- exported - imported added pitch, and came up with this
progress, a little tweaking, a couple of walls, should be fine.
But then i tried the walls
Short end of the wall (set at 1/8") is too high and the curve is wrong. sad
Heres an image of my next idea.
Can anyone out there help me with this last image please, the ideas have dried up here, thx
[Jul 14, 2016, 9:05:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Latest Doodle
voila
think i prefer the view on a lower setting
I ended up using two small triangles, start and end and then 15 small walls. Wish i'd thought of it before, DOH
[Jul 15, 2016, 11:26:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
