Half landing stairs
I have used the half landing staircase surrounded by 3 walls. But the baluster/handrail on the outside do not look nice against the walls.
With the possibility to make parts of furniture invisible it would be nice to be able to make the outer baluster/handrails invisible. Unfortunately making them invisible also make the inside baluster invisible.
@okh: I see you created this nice stairs. Any change to update the model and separate the baluster/handrails in inner and outer ones so we can control them separately?
Re: Half landing stairs
HI, Did you try to enlarge the stairs to the outer balustrade disappeared into the walls ?
India
Hi Mirakels,
BDFD is correct. Why don't you put the window in the upper level and push the handrails into the walls. If you go for invisible option then the entire handrail will be invisible.
Here's a second version of this half landing staircase with different materials for the exterior balusters/handrails. Don't forget to select the Staircase option when you'll import it.
---------------------------------------- staircase_180_landing_2.zip
(26171 bytes)
(Download count: 10146)
(Half landing staircase with different materials for handrails/balusters)
I see Puybaret beat me to it and modified the elements to exterior/interior railings. Nice.
However, I also looked at the original model which has eight different textures mapped and there are eleven staircases based on the same template. The tricky thing is to figure out which parts to make customisable without over-complicating the model.
So while the separate inside/outside solution will address one solution, I suspect there are lots of other varieties that may different customisation. In addition to Pubaret's inside/outside solution above, I throw in a couple of other versions that may be useful for different needs.
Actually, now that I think about it, the half-staircase should of course also have separately textured right/left ballusters/handrails. Put the alternatives + errata in SF 3d models 396: with the new staircase_180_landing_00_half_sep_tex.zip.
While I am not convinced it is worth the trouble to change every staircase model to have all options for customisation, it kind of makes sense with the half-staircase - made for use with a landing (just use a box, or a separate Mezzanine level with a floor). The advantage of this, is that it is possible to "build" a lot of different staircases with landings. Even if having every conceivable staircase available for SH3D is unrealistic, this approach and the current standard models, should provide a good range of options.
One problem with this small staircase, is that even if it is imported as a staircase, it will not cut out the floor above until it is raised to ceiling level. To achieve "normal" staircase behaviour, build the staircase with two (or more) half staircases + landing - adjust levels and dimensions - group and import / export as staircase (or use the Furniture Library Editor for the collated model and create a custom cut-out to satisfy the normal headroom requirement over tread: > 200-210 cm.
Using several half staircases in combination may be slightly more complicated, but it is more flexible and also solves the problem that has been annoying me, namely maintaining correct proportions when scaling a turning staircase, i.e. - angle 17°-42° (30°-36° normal), - thread depth (going): 30 - 40 cm (> 25) + nosing, - run/rise ratio (StepRise × 2 + Tread = 62 ±2 cm), - width curved staircase: > 90 cm (80 cm for straight), - and so on.
Making staircase models can be quite challenging if you want to ensure basic (not to mention legal) requirements. Many of the SH3D staircase models should be close to generic/prefabricated staircases and generally comply with normal proportions when used in normal scale. Even so, there is no guarantee that the models will satisfy local building requirements. So please do check.
Note to @Puybaret - the model appears to be working well with SH3D in my quick tests, but as I tried to keep an eye on the correct ratios/angles, I forgot to adjust height to your standard SH3D staircase dimensions (probably not a big a problem for anyone building with several elements). However, I also forgot to check for wrongly oriented normals in the model(s). Sorry.
..looks very nice now in my 'design'...
Good. Getting feedback on models is nice. Keep posting. Sometimes it is pretty hard to imagine how models will be used. Good luck with your project. ok
