Re: Cut glass
If I understand your question correctly... you can't.
Or, at least not with stock SH3D models. Instead, you'd need custom 'half' doors and windows, to give the cut-through look. Set your wall height to 4 feet (122 cm), place the special door and window objects, and you're done.
I don't *think* such models exist here or in the Sourceforge database; please correct me if I'm wrong. If I get a chance, I may try my hand at these later today.
Re: Cut glass
Thank you for answering! I hope I will stumble across someone who have made something like that, would be awesome. And If you could take a look at it aswell I would be more than greatful!
Re: Cut glass
Hei Lars,
Seems many estate agents (here) tend to use these cut-off-wall presentations of properties. As Maz says, SH3D cannot cut the (window) models in half. A half window/door model is easy enough to make. Not sure how useful such models would be, though. If you want a similar cut-off presentation, you could: 1) set wall height to 150cm (or something), 2) use invisible windows that just cut the opening. (to make a door/window invisible, use the service hatch or some other door/window and set the frame material to invisible with Modify furniture > Modify materials). You will not see the frame or window-pane, but imho the effect is close enough. So close that there may not be a need for "half" windows in the collection.
That said, the 3D exporter/viewer will allow you a more detailed and accurate view online, for instance thread 6956 and the 3D view (using the Exported homes manager).
Nevertheless, here is a very quick mock-up of a half-window (toggle invisibility/colour of elements - you still need to adjust wall height, though):
