setting new walls..
I would wish a constantly open window where you change your wall thickness as you set your wall.. set, then modify attributes, click ok, set a new (not appropriate) wall, reopen the attributes window, redefine thickness, click ok,.. this is not really fast.. Having this attribute window open all-time and of course changing the walls as you type the values, this would speed up this first step of reading in plans..
Re: setting new walls..
If you want to change the thickness of more than a wall at the same time, select them and choose the Plan > Modify walls menu item. You may even choose this menu item if the selection contains something else!
