Re: For big family
From Inside with two different ways.
1024x768 in Q3 without R1.3.1
and
1024x768 in Q4 without R1.3.1
Best rendering is in Q3 (for me) !?!
Re: For big family
Hi again bdfd. I fhought that Q3 is the best for me in the past too. But I don't think it today. 1.3.1 is much better due to high level of antialiasing etc.. All you have to know is,that Q4... or silk in 1.3.1 are much more sensitive to shiness for example. It's only about to find the best key in material settings of every simple element of each model. In 1.3.1 silk settings you have to use higher AA if you don't want to have white spots on your final picture. But the result with higher AA is great cause picture looks more plastic and realistic I think. Try try try and try only. Sure you will find it. Hope it helped you and hope you help me if I will need
Re: For big family
Thanks Martin.
And the winner is ............. R1.3.1
view from second level : 1024x768 in Q4 WITH R1.3.1 AA min..........2 AA max..........4 GI..............default DB..............1 Caustics........0 shinessShader...silk NLFD............250 NLR.............1 filter..........blackman-harris algorythm.......bucket motor rendering.sunflow
The final result is perfect.
[Edit 2 times,
last edit by bdfd at Aug 31, 2016, 6:49:50 AM]
Re: For big family
Haaaa I told you...if you find the key,you will love The difference is really visible. If I can to advise...try to decrease the shines of ficus tree leaves to total minimum. You will not have jelly leaves but really realistic tree. I am happy that you love it
Re: For big family
So I'm Lucky. I work 3 days at home and 2 at office.
Here pictures of the double garage.
Now, I include in my all projects the garage doors system (closed & open, attached to the ceiling and with wall uplights on engines).
and
[Edit 2 times,
last edit by bdfd at Sep 5, 2016, 8:26:14 AM]
Re: For big family
Here first picture of Master bedroom.
The master suite is equipped in wood stove. Further, you can see the dressing room and the bathroom.
Re: For big family
Here the dressing room Inside Master suite.
and the bathroom
Behind the little wall and blue glass there is a toilets unit. The dressing room and the bathroom have sliding doors.
[Edit 1 times,
last edit by bdfd at Sep 6, 2016, 6:41:13 AM]
