High priority Which folder to Remove to delete the default furniture Library
This topic has been viewed 19746 times and has 4 replies
Thread status: Active
Discuss anything here [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Post Reply New Topic
Vcky
Post by Vcky »
Hello. i Like to use my own models in SH3D, so i used to delete the default library of models that came included with SH3D, to minimize clutter. I cant seem to find which folder or file to remove in the SH3D folder in program files in the latest version. Can anyone help me? [:)]
User avatar
Country: Paris, France
Contact:
Re: Which folder to Remove to delete the default furniture Library
Post by Puybaret »
You should remove the file Furniture.jar found in a sub folder of the installation folder of Sweet Home 3D.
santbose
Country: Maharashtra, India
Post by santbose »
Can I remove selective models from this file?
User avatar
HawkDawg
Country: Georgia, USA
Contact:
Post by HawkDawg »
You can open jar files using 7-Zip .
Hawk
User avatar
Contact:
Post by Puybaret »
It will be tedious: if you remove some models or images, you should remove the matching piece of furniture from the DefaultFurnitureCatalog.properties and/or ContributedFurnitureCatalog.properties files (+ translation files you use if you don't run the program in English), and then update the numeric order of the pieces following the removed one, to ensure there's no missing number between two numbers (piece #1 must be followed by piece #2, then by piece #3...).
An easier way is to reorganize the Furniture.jar file as two .sh3f files by copying its com folder and the content of the DefaultFurnitureCatalog.properties file (then ContributedFurnitureCatalog.properties file for the second .sh3f file) in the PluginFurnitureCatalog.properties file of an empty new .sh3f file. Then you should be able to edit these files with the Furniture Library Editor. Unused 3D models and icons will be removed at saving time.
Who is online
Users browsing this forum: Google [Bot]
