Total posts in this thread: 7
Previous Thread This topic has been viewed 7417 times and has 6 replies Next Thread
abhishka
India
Installation doesn't work. Software doesn't start.
I have purchased this product and when installed on my Mac only the start screen comes up but no other screen. Its the home loader screen which says the name of the software.
OS - OS X Yosemite
Processor - 2.5 Ghz Intel Core i7
Memory 16GB 1600 Mhz DDR3
Startup Disk - Machintosh HD
Graphics - AMD Radeon R9 M370x 2048 MB
[Sep 9, 2016, 2:31:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Installation doesn't work. Software doesn't start.
Really strange... This kind of problem may happen on other systems, but not on macOS sad
Would you be able to run Sweet Home 3D from a Terminal window to report here the messages it will say? Simply drag and drop Sweet Home 3D application in a Terminal window, type back space, copy-paste /Contents/MacOS/SweetHome3D and press enter.
You could try also the free version but it will require that you install Java 6 too.
[Sep 12, 2016, 5:26:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
martyt3
United Kingdom
It wont start for me either. Im on win 7
[Sep 22, 2016, 5:44:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Martyt3, could you try version 5.3 beta 7?
[Oct 20, 2016, 12:01:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jlecour
I have a similar issue. The program starts, I get the spashscreen, but it's frozen.
~ → /Users/jlecour/Desktop/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
[JavaAppLauncher] Requested [1.5*], launching in [1.8] instead.
Java 3D: implicit antialiasing enabled
Exception in thread "J3D-Renderer-1" java.lang.UnsatisfiedLinkError: no jogl in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at com.sun.opengl.impl.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:189)
at com.sun.opengl.impl.NativeLibLoader.access$000(NativeLibLoader.java:49)
at com.sun.opengl.impl.NativeLibLoader$DefaultAction.loadLibrary(NativeLibLoader.java:80)
at com.sun.opengl.impl.NativeLibLoader.loadLibrary(NativeLibLoader.java:103)
at com.sun.opengl.impl.NativeLibLoader.access$200(NativeLibLoader.java:49)
at com.sun.opengl.impl.NativeLibLoader$1.run(NativeLibLoader.java:111)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.opengl.impl.NativeLibLoader.loadCore(NativeLibLoader.java:109)
at com.sun.opengl.impl.macosx.MacOSXGLDrawableFactory.<clinit>(MacOSXGLDrawableFactory.java:53)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at javax.media.opengl.GLDrawableFactory.getFactory(GLDrawableFactory.java:108)
at javax.media.j3d.JoglPipeline$QueryCanvas.<init>(JoglPipeline.java:9029)
at javax.media.j3d.JoglPipeline.getBestConfiguration(JoglPipeline.java:8793)
at javax.media.j3d.Renderer.doWork(Renderer.java:514)
at javax.media.j3d.J3dThread.run(J3dThread.java:275)
[Nov 20, 2016, 3:03:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Jeremy, the first message of this thread talks about the Mac App Store version. Are you sure you're talking about that version or the free version? If it's the free version, would you have some jar files in the folder ~/Library/Java/Extensions if it exists? If it's the case, remove them, it should work better.
[Nov 20, 2016, 3:24:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jlecour
Right, I'm using the free version. I didn't notice that aspect. Sorry.
Also, the "~/Library/Java/Extensions" doesn't exist (not even "~/Library/Java").
[Nov 20, 2016, 9:05:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
