Posts: 200   Pages: 20   [ Previous Page | 11 12 13 14 15 16 17 18 19 20 | Next Page ]
Previous Thread This topic has been viewed 213429 times and has 199 replies Next Thread
Re: 2040 : Mars Two
Thank you Lady Vero. smile
The bricks are arrived at the cupola to finish the wall.
1920 x 1080 in Q4
The closer view shows the rover with its trailer (with 6x6 wheels).
[Dec 27, 2016, 10:52:31 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
D 290
The assembly of the structure of the dome began.
1920 x 1080 in Q4
Captain hopes that it will be finish for the new year.
[Dec 29, 2016, 9:05:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
12/31/2040
The captain is happy ! smile
The structure is finished... we can do the fest this night ! laughing
Tomorrow in the evening (after a good night) we will install the inflatable cupola.
In the right background (1 km from base camp), we can see the site with its solar panel which produce Methane, water and O².
[Dec 31, 2016, 7:48:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
All the crew on Mars wish you a Happy New Year (to) Earth !
1920 x 1080 in Q4
In the sky, you can see the fireworks and ISV Hermes passes over the base camp...
[Edit 1 times, last edit by bdfd at Dec 31, 2016, 6:04:48 PM]
[Dec 31, 2016, 5:49:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
Happy New Year to you, bdfd, your crew and all Sweet Home 3D users! Thanks for accepting to answer to our questions smile
[Jan 1, 2017, 3:26:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
Thank you Emmanuel.
Long life and prosper !
01/01/2041 : The new year begins well (D 295), the inflatable cupola is OK.
1920 x 1080 in Q4
The crew will be able to live in while creating it.
Finish the 'little' accomodation module. smile
The dome is made up of 2 inflatable envelopes:
The first outer side (10 mm) is filled with ozone to filter the UV rays,
The second inner side (20 mm) is filled with water to protect from other radiations.
Mars will be able to host the next missions.
[Jan 1, 2017, 5:10:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
Come back aboard the ISV Hermes and the last part : the Propulsion module.
1920 x 1080 in Q4
To protect the crew, there is a vaccum between the Accomodation module and the Propulsion module.
[Jan 2, 2017, 6:00:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
Inside the airlock module, the crew sees the twice parts : front airlock and the main console of the engines.
Main console
Front airlock
1024 x 768 in Q4
After the silence of space, 'vrrrmmmmmmmmmmmmmm' the noise of the engines... laughing
[Edit 1 times, last edit by bdfd at Jan 3, 2017, 6:16:55 AM]
[Jan 3, 2017, 6:08:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
We arrive into the machines room 'Scotty'... laughing
1024 x 768 in Q4
there is Lot of noise and it's a hot location... devilish
[Jan 4, 2017, 7:15:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
We arrive at the central part of the machines room.
1024 x 768 in Q4
[Jan 5, 2017, 6:04:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
