Posts: 200   Pages: 20   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Previous Thread This topic has been viewed 213432 times and has 199 replies Next Thread
Re: 2040 : Mars Two
thank you Earth.
This is confirmed by the crew of Hermes above us.
We check the anchors and return equipments in the hangars.
The crew of Mars Two will remain safe.
All batteries are ON.
News (for Manu):
The atmospheric pressure there is in fact only 9 millibars against 1013 millibars on Earth.
The atmosphere is so thin that winds of 150 km/h would not make you more impact than cigarette smoke on the cheek...
The real danger comes from dust.
it contains perchlorate, silica, iron oxide and sulfur in very fine sizes and very static... biggrin
Completed !
[Edit 1 times, last edit by bdfd at Oct 13, 2016, 9:29:13 AM]
[Oct 13, 2016, 5:12:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
9 millibars! Then, parachutes must be giant!!!
About communications, the long delays when they communicate with the Earth must make the astronauts feel like if they use a slow speed connection!
Hope the storm won't last too long wink
[Oct 13, 2016, 10:28:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
Waiting the dusty storm ends, here are specifications of the main rover.
[Edit 1 times, last edit by bdfd at Oct 13, 2016, 5:58:59 PM]
[Oct 13, 2016, 5:58:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
UPDATES
So if Mars One was in Orson Welles crater (purple cross bottom Xanthe),
Mars Two is in Taytay crater (green cross between Pathfinder and Opportunity sites) near river of Ares vallis.
Follow the black arrows.
Mars map download HERE
Storm is entirely on the planet, here pictures from meteorologic satelite in orbit.
There are signs of improvement for the storm stops tomorrow. smile
If No, before we have installed 3 Wind turbines.
thinking
[Edit 2 times, last edit by bdfd at Oct 14, 2016, 1:01:09 PM]
[Oct 14, 2016, 7:00:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
D 215
2 groups form, the scientists and the builders.
During the storm in the hangar, the first prepares their exploration mission.
They ended the exploration rover (extended main rover) in the hangar-1b.
It is expected for the full crew is 11 people.
For scientific explorations 4 will leave.
The rear part of the rover will serve as storage.
Spécifications of exploration rover
After this, they will continue with the survival module.
The second prepares the communications module...
[Oct 15, 2016, 7:41:28 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
D 216
Now, they are in hangar-1a.
They prepare the Survival module.
A 'tiny martian house' of more 25.5 m²
Here are the plan and the spécifications.
and
[Oct 15, 2016, 6:12:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
D 218
The storm ended.
Fortunately the 3 wind turbines worked well...
Hermes gave us this photo above base camp.
Do you see the base camp (little white dot on S) ? biggrin
TO BE CONTINUED...
[Edit 1 times, last edit by bdfd at Oct 17, 2016, 4:00:41 PM]
[Oct 16, 2016, 2:57:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
D 222
Here the communications module builds by second group.
1920 x 1080 in Q4
Here the specifications of this module.
[Edit 1 times, last edit by bdfd at Oct 17, 2016, 4:18:27 PM]
[Oct 17, 2016, 4:07:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 2040 : Mars Two
D 225
The 'builders' are on the propellant module.
1024 x 768 in Q4
[Oct 19, 2016, 7:00:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AeowynFraser
Re: 2040 : Mars Two
Wow, there is so much that must be done when we get to Mars! Very awe-inspiring!
[Oct 19, 2016, 7:07:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
