Features
Total posts in this thread: 6
Previous Thread This topic has been viewed 5055 times and has 5 replies Next Thread
JuanEDC
How can I create a ramp?
Hello, I'm doing an underground parking, so, somebody knows how can I create a ramp or a triangle to simulate the inclined road to the parking places?? Thank you for the help.
[Sep 22, 2016 3:48:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How can I create a ramp?
Use a triangle (or other shape) placed at the lower level - i.e. in the ground. There are several threads about this in the forum, but I cannot find them off hand. Good luck. ok
[Sep 22, 2016 8:34:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
kevinw.randolph@gmail.com
US
Hello, I would suggest considering just using a wall, double clicking it and then choose the 'Sloping wall' option. Give it a thickness to represent the width of the ramp. Height start and end provide the slope desired. It worked out in a quick test I did.
[Oct 1, 2016 1:08:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The triangle or shape and the wall would both work well, the wall has the advantage that it can be arced but the disadvantage that it has a minimum height, which may be higher than the floor.
[Oct 1, 2016 7:42:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
There is a ramp in the example 6 of the Gallery (made with a triangle, in the basement)
[Oct 4, 2016 3:34:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
You can see one of my projects HERE
There are three ramps at different levels... Shape, wall or triangle are the same thing, it's not easy to locate them.
only 6.0 and nothing else - W10 64b
[Oct 4, 2016 7:50:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
