Previous Thread This topic has been viewed 7229 times and has 2 replies Next Thread
jaffguo
How to add a shortcut key to my plugin menu item?
I'm wondering if there would be a way to add a shortcut key to my customized plugin menu item.
thanks,
jaff
[Oct 28, 2016, 10:06:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to add a shortcut key to my plugin menu item?
You can add shortcut by binding an instance of KeyStroke with an action that will execute your plugin. The good place to program this should be in the method getActions of your plug-in :
public PluginAction [] getActions() {
final PluginAction pluginAction = new PluginActionClass(...);
// Create shortcut once Sweet Home 3D window is created
SwingUtilities.invokeLater(new Runnable() {
public void run() {
// KeyStroke for shortcut Ctrl+Alt+Shift+C (cmd+alt+shift+C under Mac OS X)
KeyStroke cmdOrCtrlAltShiftC = KeyStroke.getKeyStroke(KeyEvent.VK_C,
Toolkit.getDefaultToolkit().getMenuShortcutKeyMask()
| KeyEvent.ALT_DOWN_MASK
| KeyEvent.SHIFT_DOWN_MASK);
// Bind shortcut with the key "MY_KEY"
JComponent homePane = (JComponent)getHomeController().getView();
String actionKey = "MY_KEY";
homePane.getInputMap(JComponent.WHEN_IN_FOCUSED_WINDOW).
put(cmdOrCtrlAltShiftC, actionKey);
// Bind the key "MY_KEY" with an action that will execute the plug-in
homePane.getActionMap().put(actionKey, new AbstractAction() {
public void actionPerformed(ActionEvent e) {
pluginAction.execute();
return new PluginAction [] {pluginAction};
If you want that the shortcut appears beside the menu item of the plug-in, you'll have to find the menu item in the menu bar returned by
((JFrame)SwingUtilities.getWindowAncestor((JComponent)getHomeController().getView())).
getJMenuBar();
with getMenu then getMenuComponent methods. Once you found the right menu item, just call its setAccelerator method.
[Nov 2, 2016, 3:33:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
jaffguo
smile Re: How to add a shortcut key to my plugin menu item?
I very much appreciate your help, Ennanuel. It works well. Thanks a lot.
Jaff
[Nov 3, 2016, 12:20:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
