Photo-video rendering plug-in
This topic has been viewed 2479003 times and has 270 replies
Thread status: Active
Test the features and bug fixes of future versions [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
enkonyito
Post by enkonyito »
@hansmex
Even better: create the possibility to specify the size of the image preview in Preferences... :-)
I will study the feasibility of the thing so as not to complicate the photo panel too much.
Besides, I hesitated to put the option of the choice of look and feel in the preferences if it was possible.
EnkoNyito
User avatar
Country: Copenhagen, Denmark
Contact:
Post by Ceciliabr »
Maybe you could make the plugin-window resizable?
That would meet every individual need,
ndorigatti
Country: Italia
Post by ndorigatti »
Heheheh I think it would be though... Java and Swing (programming language and UI components used here) are not the best to support responsive layouts...
I hope it is possible, but I have a few ideas/options for the developer:
- What about changing the Quality bar? we have only 4 options and it is huge, fast and best are taking a lot of space in addition to 1-2-3-4.... Maybe replace 1 and 4 with fast and best and keep 2 and 3 instead of replacing the whole component?
The lookAndFeel (that I did not understand why having that option, but maybe I missed some thread) should be a non frequent option to change (it is less important than picture size or quality, so it could stay in a "secondary" frame like advanced options, why not?
So we could have a new frame with:
Look and feel - Preview Picture Size - Any other option
And, this is completely IMHO, I would put the elapsed time bar under the "Advanced settings / Enhance Brightness" line, just to separate what will change the resulting image and require a stop-create (over that line) and what is modifying in live the UI and the components shown (below the progress bar), like lookandfeel.
Take this as some ideas from a developer that uses SH3D sometimes, and used a lot when planning a new home, so if you think is a stupid idea, feel free to tell it! [:D] [:D]
enkonyito
Post by enkonyito »
@Ceciliabr
Maybe you could make the plugin-window resizable? That would meet every individual need
Proof by the image.
EnkoNyito
enkonyito
Post by enkonyito »
@ndorigatti
The goal of the plug-in is to stay visually close to the standard photo panel while providing new options.
Personally, I occasionally use quality level 1 (3D view without shadow) and one of the higher quality levels (3 or 4) with the setting of SunFlow rendering engine.
This option is not related to the rendering but I have integrated it in the photo panel in order to modify the appearance of the interface.
The other solution is to use a script for the installer version as shown here with "-Dswing.defaultlaf=".
Available Look and Feels:
Code: Select all
javax.swing.plaf.metal.MetalLookAndFeel
javax.swing.plaf.nimbus.NimbusLookAndFeel
com.sun.java.swing.plaf.motif.MotifLookAndFeel
com.sun.java.swing.plaf.windows.WindowsLookAndFeel
com.sun.java.swing.plaf.windows.WindowsClassicLookAndFeel
This may be possible (see previous central image).
EnkoNyito
mirakels
Post by mirakels »
Maybe make 'quality' a drop down menu... It only has 4 choices so why a slider does not add much functionality
User avatar
Contact:
Post by Ceciliabr »
@enkonyito
Resizable is king!
Now the next, ( and probably impossible) challenge is: Can the resizable photo renderer include a 3D preview? It would really "revolutionise" this program to have a combined preview- and render-window.
enkonyito
Post by enkonyito »
Version 1.4.1
- resizable photo panel with modified layout
- display of the current version of the plug-in in the menu
Thanks to my beta testers Ceciliabr and hansmex for their feedback and to Emmanuel Puybaret for his advice! [;)]
EnkoNyito
User avatar
Contact:
Post by Ceciliabr »
Resizable renderer with rendering in progress:
cec
User avatar
Country: LILLE, Les Hauts de France, Western Europa
Post by bdfd »
It's not my first installed plugin... but I got a problem.
I don't see anything :
1. in the options menu
2. in librairies list
3. but plugin is in the good sub-directory (green Arrow)
An idea ?
Post Reply New Topic
