Simple passive house
90 seconds introduction to passive house YouTube video
Passive House is a building standard that is truly energy efficient, comfortable and affordable at the same time. Passive Houses allow for space heating and cooling related energy savings of up to 90% compared with typical building stock and over 75% compared to average new builds.
This is my simple (flat roof makes it "modern" ) passive house. BTW you can use passive house principles for any kind of structures (house, skyscraper...).
Re: Simple passive house
Thanks for starting this topic. Clever energy usage is pretty important - not only for new constructions, but also for modifications. And there are some interesting energy saving solutions available. You can find some links along the same lines (albeit with off-grid in mind) in a previous thread too: 5826.
Good approach for a so big subject.
You can see HERE in same style or HERE that many subjects have been seen:
Orientation (South), Solar panels (electricity and hot water), vertical geothermal heating, wood stove, Climate well, Wind turbine, ...
To be complete, I upload again the third missing pictures.
The plan
Street view
East view
[Edit 2 times,
last edit by bdfd at Dec 23, 2016, 9:15:13 AM]
I fell in love with passive house concept because it just makes sense. It's nothing special just smart.
Yes, passive houses - or even plus-houses - are very interesting. And I agree that the idea is smart. Talked to an engineer a while back. While he too was very positive to the very energy efficient houses, he had some issues with the standards about to be implemented many places and the level of complication it added to a house. Specifically about ventilation and heat exchange. Point being that some builders are not really sufficiently experienced to build a passive house and that some attempts had some problems with air flow. But - if you get it right - it is certainly the future. ok
And how can you install it ? HERE
For someone that knows near to nothing about Passive House the name itself "passive" can be misleading. Passive refers to extremly low energy consumption (90% less then "normal" house) and in all other aspects, like using renewable energy, this kind of house is very active.
So smart flower tech is exactly what Passive House is all about.
And therefore active means that it produces more energy (> 100%) than it does.
Passive is a good start, but not enough because passive = dependencies.
Active = Autonomy !
