Egypt
Stair Rail
How can i solve my problem with the iron rail that i want to add to an inclined wall side of a garden stair. I was trying to make a custom rail , but when i failed i tried to get a 3d model of rail but i have a new problem.Can i get some help,Thanks. http://www.mediafire.com/view/fnfrm3lrb7768c7/Stair_Rails.jpg
Re: Stair Rail
You must export the rail (in obj format) and re-import it. When you will be with the box and the green arrows, push it in right direction with SHIFT and green Arrow like you want...
Or find a good model in 3D Warehouse.com
Egypt
Re: Stair Rail
My Problem is to align it with the inclined wall I found inclined rail but the problem with me to complete with the same rail in the horizontal So if i find the inclined one i can't continue with the same one on the horizontal wall and vice versa
[Edit 1 times,
last edit by bdfd at Dec 28, 2016, 7:20:36 AM]
Romania
Re: Stair Rail
If this is what You want
then follow next steps otherwise... ask again -download this furniture -import them in SH3D and then in 2D plan -will look strange
It's a 3 in 1 furniture. -right clik -> Modify furniture -> Materials:Modify
-on materials dialog
select which You don't need and make them invisible. In this case I chose to keep 30 deg. Will look like this in the end
For this task I use the original furniture and modify them in AOI P.S. Off course You can change the color(texture) and don't forget to use the mirror shape when You need. Hope to be helpful and HAPPY NEW YEAR to Everibody
---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law (Greer's Third Law) When all else fails, read the instructions.Murphy's Law
