Total posts in this thread: 4
Previous Thread This topic has been viewed 9664 times and has 3 replies Next Thread
enkonyito
Spherical sky without 3D ground
Is it possible to modify the source code of SH3D to "hide" the 3D ground in order to use an HDRI image in a spherical sky?
EnkoNyito
[Jan 3, 2017, 3:57:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Re: Spherical sky without 3D ground
It is possible to hide the creation of 3D ground in the PhotoRenderer.java file.
A simple solution is to use an invisible texture for the ground in SH3D but the .hdr format is not supported as sky texture. sad
Here are the results obtained in Sunflow with .hdr files.
With ground
Without ground
EnkoNyito
[Mar 30, 2017, 1:29:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Interesting! Thank you for proposing this solution. But the rabbit is flying, now...
[Apr 1, 2017, 4:43:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
The Sunflow interface is not convenient for viewing scene changes.
Blender accepts the .hdr format, you could better place a 3D object so that it fits into a real image.
Maybe one day Sweet Home 3D will also accept this image format.
EnkoNyito
[Apr 8, 2017, 1:14:27 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
