Features
Total posts in this thread: 2
Previous Thread This topic has been viewed 6525 times and has 1 reply Next Thread
gaira
confused Is it possible to export positions, orientations, and properties of all the furniture?
If it's not, what is the API to access such information?
I found a button to export the names and dimensions of furniture as CSV file, but what I need is basically all the information that's used to generate sh3d file. If I could unbinalize the sh3d file, it may also suffice the purpose. I'm reading the java doc, but unfortunately it is a little overwhelming for a programming beginner. Could somebody please give me a pointer?
Thank you very much in advance.
[Jan 14, 2017 8:03:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Is it possible to export positions, orientations, and properties of all the furniture?
A .sh3d file is actually a zip file containing a Home.xml entry that describes the drawn home with furniture, walls, rooms... coordinates, and references the images and 3D models stored in the other zipped entries. The DTD of this XML file is given in HomeXMLHandler javadoc and here.
Read also the threads about Sweet Home 3D 5.3 and about Export to XML/OBJ plug-in.
[Jan 14, 2017 11:33:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
