[Edit 1 times,
last edit by bdfd at Apr 2, 2017, 6:48:52 AM]
Re: Modern house(s)
Nice idea bdfd, but where are the solenoid valves, pipework, limit swith's and compressor to make this work? And what about the cylinder length 40 cm of movement means atleast 60 cm of fixed cylinder
Re: Modern house(s)
Nice idea bdfd, but where are the solenoid valves, pipework, limit swith's and compressor to make this work? And what about the cylinder length 40 cm of movement means atleast 60 cm of fixed cylinder Mike
Thanks Miker.
Only higher cylinders are seen. All pneumatic parts are lower in the walls, sheltered from 'cold' winter and wet spring or autumn.
Re: Modern house(s)
Here is a new cubic model with 2 floors.
Plan:
This modern house is equipped with : A second big terrace on the first roof, solar panel for hot water, solar panel for electricity, a carport for a second car and a surprise... never seen in SH3D's world... I hope.
From North-West view
1920 x 1080 in Q4
[Edit 1 times,
last edit by bdfd at Apr 5, 2017, 8:53:32 AM]
Re: Modern house(s)
Here is the south-east view with THE surprise !
1920 x 1080 in Q4
Do you see the surprise ? A semi-circular veranda called a 'LUMICENE'. I made this new object in two positions : opened and closed based on a real french product from Lumicene's enterprises.
Here is a real photo of Lumicene in semi-opened mode.
Interested by the concept, follow this link HERE in English or french.
[Edit 3 times,
last edit by bdfd at Apr 23, 2017, 7:03:38 AM]
