Features
Total posts in this thread: 4
Previous Thread This topic has been viewed 2465 times and has 3 replies Next Thread
rhawke
United States
Recalculate Room Points
After I move a wall by a few inches or move a door left or right along a wall, I have to update the room. Right now the easiest way is to delete the room and add it again with double click (because fixing the room to match a moved door manually takes a long time).
But then I have to select the textures again, change labels, etc.
It would be nice to have a button inside the "Modify Room" dialog box that lets you recalculate the room points (basically same calculation as when I double click in the center of the room). You could simulate this by assuming I double clicked into the center of the selected room.
Or is there already a good approach to this problem that I am missing?
[Jan 27, 2017 7:19:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Recalculate Room Points
I had the idea to add an option to recalculate rooms like you proposed.
But I already introduced a solution to simplify this operation: cut the room, create the room with double click and select Edit > Paste style menu item.
[Jan 27, 2017 4:52:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
rhawke
United States
Thanks Emmanuel, this is a good tip. I will use this from now on!
For new users the idea to have a button to recalculate would be nice though, so if it is easy to implement I think it would a way to make the software even more intuitive and user friendly (It already is AWESOME!)
[Jan 27, 2017 5:04:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Hi rhawke
Sounds like a good idea to me, i never get door positions right 1st time, or 2nd come to that.
[Jan 27, 2017 7:10:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
