Request:
make the ability to set the transparency for the walls.
need manual transparency level from 0 to 100%
this is to allow for a 3D plan is more convenient positioning of objects.
[Note from moderator: removed Russian translation]
Transparent wall
This topic has been viewed 24625 times and has 6 replies
Re: Transparent wall
What about using the Walls transparency slider available in the 3D view modification dialog box?
as a simple option - for all the walls in the 3D dialog.
but it is better in the properties dialog for the selected wall wall. to make transparent (translucent)
Wall dialog box offers already a lot of options, and I don't think this additional option is interesting enough to add it.
Transparency may be added into color dialog box / texture import ?
Playing with wall transparency individually (at the opposite of 3d view settings which is global). Transparent walls can be a way to work around lack of roof modeling.
Can one make walls transparent on the 2D plan? The only way I can is by clicking and holding on them, but I would like to see the portion of the background image covered by walls without having to click and hold on them, lest I move them inadvertently.
No you can't make walls permanently transparent in the plan.
Who is online
