Features
Total posts in this thread: 6
Previous Thread This topic has been viewed 3316 times and has 5 replies Next Thread
Gymnos
Australia
sad Objects with texture
I have made some furniture in "Sketchup" and some people in "Makehuman"but when I try and import them they loose their texture.
I have tried various formats OBJ and DAE but the only difference is grey or clay colour. What have I done wrong.
[Feb 23, 2017 4:49:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Objects with texture
DAE and OBJ models come with a separate directory for the textures. If you move the model, you should move the directory as well so that the relative path stays the same.
If you don't do that, the model will be white.
[Feb 23, 2017 9:41:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
picmau
@hansmex may you please help me explainig which are the step I have to do to "move the directory as well so that the relative path stays the same"?
Sorry but I am rally not expert sad
[May 11, 2018 5:31:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
picmau
Is there anyone can help me?
[May 15, 2018 12:37:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The easiest, I guess, is not to move anything before using Import Furniture in SH3D. That is, import them from where you originally saved the DAE or OBJ files...
If you need to move them,
OBJ requires:
xxx.obj (the .obj file itself)
xxx.mtl (specifies the materials used)
xyz.jpg / xzz.png (texture files referenced in the .mtl file)
DAE requires:
xxx.dae (the .dae file)
and usually a directory with the same name (xxx or whatever) with texture files (.jpg/.png/.gif)
So if you go to your export directory and select the above and move them together, it should work.
[May 15, 2018 7:53:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
And to complete okh good suggestion, once imported in Sweet Home 3D, you can then move or even delete the downloaded files.
[May 15, 2018 8:42:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest    http://www.eteks.com [Link] Report threatening or abusive post: please login first  Go to top
© Copyright 2006-2019 eTeks - All rights reserved
