Previous Thread This topic has been viewed 10549 times and has 10 replies Next Thread
denis_sh3d
confused macOS Sierra - Sweet Home 3D 5.4 - very slow
Good morning,
I've updated to macOS Sierra coming from EL Capitan and since this update Sweet Home 3D is running pretty sluggish. The 3D view is stuttering and the whole 2D view is slow as well. I got an i7 processor with 16 GB of RAM so this should be fine. Other java stuff like Android Studio or Minecraft does run normally.
Has someone experience the same and can help me?
Thank you very much.
Denis
[Mar 5, 2017, 7:21:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
denis_sh3d
Re: macOS Sierra - Sweet Home 3D 5.4 - very slow
I'd like to add even when giving it more than the 1GB max RAM (4096 or even more) it does run pretty slow. :(
[Mar 5, 2017, 7:31:06 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What is the version of SH3D ? => 5.4 ?
What is the size of the SH3D file which gives this problem ?
[Mar 5, 2017, 8:10:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
denis_sh3d
The Version is 5.4. The filesize is 48MB. I am using the project on my Macbook Pro for now running Yosemite since it is unusable on macOS Sierra. (the Macbook Pro is less powerful with less RAM) Yesterday I was using the the same machine with El Capitan and it was fast and smooth. Today on macOS Sierra it is sluggish like hell. Even resizing the 2D window is damn slow.
I'm open for every advice. If I can deliver more logs or something else for debugging the problem just drop me a message and I'm collecting it for you.
Denis
[Mar 5, 2017, 5:56:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I would suggest to install Java 8 and try the Java Web Start version. As this version will use an other version of Java and of the 3D engine, it might run better.
[Mar 6, 2017, 12:35:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
denis_sh3d
The web start version does run smooth as silk. :-) Thank you very much.
[Mar 9, 2017, 5:34:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
denis_sh3d
The only problem remaining is that I am not able to render images at the best quality level anymore. I'm getting a red cross. This did work with the normal download version of Sweet Home 3D. Any suggestions?
[Mar 11, 2017, 9:50:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
I suggest that you read, in the FAQ, this chapter: How can I adjust the memory used by Sweet Home 3D?
[Mar 11, 2017, 11:49:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I has had the same problem more times when the projects had too objects inside.
With a copy, try to remove few objects and try again...
[Mar 12, 2017, 5:33:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
denis_sh3d
Is there a way to raise the available memory to the web starter version of SH3D?
[Mar 12, 2017, 9:14:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
