Features
Total posts in this thread: 5
Previous Thread This topic has been viewed 4797 times and has 4 replies Next Thread
norseman
Fluorescent light bar for ceiling
Hello everyone.
Started using this program a couple of days ago. The reason for starting using it is that we are moving our workshop.
I thought it would be nice to 3D it, in order to visualize how it will look.
So far, so good.
However, when adding lights to the various rooms, I could not fin any flurescent lights/bars for the ceiling.
Found a free object, and I got myself really worked up :-)
Unfortunately, there was no light properties!
I will be grateful for any suggestions
Regards Tore
[Mar 13, 2017 12:18:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
Re: Fluorescent light bar for ceiling
You must add light sources yourself.
only 6.0 and nothing else - W10 64b
[Mar 13, 2017 3:30:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
There are two fluorescent light bars in the 3D models.
By the way, there are many advices about lights in this tip
[Mar 13, 2017 8:15:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
norseman
Thanks for your advice. The default lights supplied have light properties that you can adjust. Any link to how I add this to for example a light strip?
[Mar 13, 2017 11:00:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
You can add light-sources by using the supplied light sources, OR add light source properties to models editing the Furniture libraries (in the extra properties SH3D uses for models).
Either way, the light sources will always be spheres, so you need to simulate the light from a light strip with one or more light spheres. In addition to Veroniques hint about the blog, you can find lots of good light source tips in the forum.
Your best bet is probably to use several slightly scaled up light sources under the light strip (group them with the light strip so they are easy to duplicate and move around together).
Lykke til med verkstedflyttingen.
[Mar 14, 2017 7:23:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message    Hidden to Guest [Link] Report threatening or abusive post: please login first  Go to top
