Re: Fluorescent light bar for ceiling
Thanks for your advice. The default lights supplied have light properties that you can adjust. Any link to how I add this to for example a light strip?
You can add light-sources by using the supplied light sources, OR add light source properties to models editing the Furniture libraries (in the extra properties SH3D uses for models).
Either way, the light sources will always be spheres, so you need to simulate the light from a light strip with one or more light spheres. In addition to Veroniques hint about the blog, you can find lots of good light source tips in the forum.
Your best bet is probably to use several slightly scaled up light sources under the light strip (group them with the light strip so they are easy to duplicate and move around together).
