Total posts in this thread: 2
Previous Thread This topic has been viewed 1965 times and has 1 reply Next Thread
Zheka77
Slovenia
End sides of walls
Hello, dear community.
Question - painting the walls (outer and inner sides), the end sides (not upper side of the walls are being divided by to vertical parts with inner and outer paint accordingly. How can i hide this?
[Edit 1 times, last edit by puybaret at Mar 14, 2017, 11:34:47 PM]
[Mar 14, 2017, 1:38:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: End sides of walls
We have had all this problem in the beginning.
There are three solutions in fact.
1. You must build the walls in continue.
=> Not easy in the beginning of a project. biggrin
2. You Built the walls separatly (2a) and you joined them manually after (2b).
You'll have a little default in the corner.
=> It's fast but not beautiful. sad
3. You must download and install a plugin* with an option named 'Connect the walls' available in the 'Plan menu'.
=> It's the better for us. love struck
(*) The plugin is in AdvancedEditing.sh3p made by Tobias Liefke which you'll find in 'plugin section'.
[Edit 1 times, last edit by bdfd at Mar 15, 2017, 6:23:13 AM]
[Mar 15, 2017, 6:20:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
