Features
Total posts in this thread: 5
Previous Thread This topic has been viewed 1848 times and has 4 replies Next Thread
sergiopss
Generated Photo is always blank
After adding a room to my project, after that moment I can't generate anymore a photo or video in hight quality when using "Virtual Visit" view since the generate image is always blank.
If I delete the room is ok again.
Here is a print screen for best understanding: IMAGE
I've searched for possible fix but without results...
Any help?
Thanks.
[Mar 31, 2017 4:39:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Generated Photo is always blank
Any help?
Thanks.
I had the same problem after adding a fairly large object. crying
We have thus reached the possibilities of the software (either in memory or in the number of objects present, ...).
You need to simplify your project...
only 5.7 and nothing else - W10 64b
[Mar 31, 2017 5:15:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sergiopss
Hi, thanks for the reply but that's not a solution since I'm only making a simple prototype... I only have about 10 simple objects and this only happens when I add the room, even without textures.
[Mar 31, 2017 5:43:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sergiopss
Hummm, my bad...
I just realize that my view probably was above the ceiling (can't realize that on the 3d view).
When rendering, it was rendering by beautiful white ceiling...
Problem solved!
[Mar 31, 2017 6:09:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hummm, my bad...
Problem solved!
OK !
The center of the point of view had moved... laughing
[Mar 31, 2017 7:29:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
