ALERT : Win10 build 1703
After download and installing new Win10 build 1703, I saw that sh3d crashed !
In opening, no problem.
I tryed to do a 'Save Under...' and bye... No message...
When you re-try to open sh3d's file, do a simple 'Save' on a recuperated file, this resoluted the problem.
So, becareful !
====> 04-07-2017 - 15:21 GMT
1. Same crash when I want to import new model in existant project. When I choose 'Furniture', 'Import furniture', 'choose model'........... CRASH ! similar to departure without saving.
[Edit 4 times,
last edit by bdfd at Apr 8, 2017, 6:33:43 AM]
Sure this is a bug author needs to fix, but I can see a workaround in renaming that folder
Good idea but LOST !
Same crashes without french accents...
Re: ALERT : Win10 build 1703
@Manu : What are the news ?
It looks like the Java bug #8170517 or #8173471. The first one was closed as non-reproducible and the second one was resolved recently but the fix is probably not published yet. The bug must happen as soon as you try to access a file dialog box to choose a sh3d file or any other file handled by Sweet Home 3D, with a problem to access this file. To cancel the directories that you used recently in Sweet Home 3D, run regedit, search for last/Directory# and last/Default/Directory in folders ending with com/eteks/sweethome3d and remove matching entries. If it doesn't work better after that, try to move and open a Sweet Home 3D file in a very common place like your desktop to check if it works better or not.
No change after remove all entries in "\HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\eteks\sweethome3d"...
Same crash with : - Save Under - choose new furniture - save picture...
Why does it work with 'Save and compress' and NOT with 'Save' or 'Save as' ?
Another ideas ?
perhaps with java 1.9 ?
[Edit 2 times,
last edit by bdfd at Apr 12, 2017, 12:33:41 PM]
I just tried on a Windows 10 computer with Creator update (version 1703 / 15063.138), and didn't notice any issue. You can try with Java 9 + Jar executable version for example, but keep in mind that Java 9 is still in Beta.
OK, we have same OS with the latest update (yesterday).
So I saw a sub-directory jre8 in sh3d directory, I deleted it. I launched sh3d and...
So I copied/pasted the jre-9 in programs directory into sh3d directory. I launched sh3d and...
I deleted all plug-ins, same crashes... I desactived my anti-virus, same crashes...
Latest updates after win10 1703
here is the latest logs :
What can I do more ?
Even the soft "Furniture Library Editor" crashes... see the last joined log.
---------------------------------------- hs_err_pid3352.log
(41147 bytes)
(Download count: 132)
[Edit 3 times,
last edit by bdfd at Apr 13, 2017, 8:50:52 AM]
