Re: ALERT : Win10 build 1703
As suggested in my previous post, please try with the Jar executable version.
OK, it's done.
I launched it by double-click on jar file and...
I saw only this :
And no more ?
No log !
[Edit 1 times,
last edit by bdfd at Apr 13, 2017, 1:56:22 PM]
Even if Java 9 is still in beta version, I wished the program could run a little further You could launch the program in a cmd window with a command like:
java -jar path\to\SweetHome3D-5.4.jar
The logged errors displayed in the console you give some hints to go further...
Thanks Manu.
Here is the log of the command :
And I forgot the log's file (xxx8304.log) with return on java 1.8.0_51 :
---------------------------------------- j9log.txt
(3378 bytes)
(Download count: 78)
[Edit 3 times,
last edit by bdfd at Apr 13, 2017, 2:36:20 PM]
A new downloading and installation of Win10 build 1703 (15063.138) on a mobile computer (core i3) gave EXCELLENT results...
I do same thing on my another desktop ! I don't understand...
[Edit 1 times,
last edit by bdfd at Apr 14, 2017, 5:54:50 AM]
This morning, a new installation of Win10 build 1703 (15063.138) on my desktop (core i7) did not give good results...
sh3d always crashes...
Same thing with sh3d 4.6 & 5.3 !
[Edit 2 times,
last edit by bdfd at Apr 14, 2017, 9:26:25 AM]
Do you have any news about my problem seen on apr 07th ?
I think to make a good diagnosis, you just compare why there are differences between 'Save' (NOK) and 'Save and compress' (OK) actions and find out what can cause these crashes, right ?
We have the effects, you must find the reason... and the solution.
I hope that the last logs are speaking themselves.
[Edit 1 times,
last edit by bdfd at Apr 14, 2017, 5:56:17 PM]
As said before, this bug seems to be bound to the file dialog box, and on a brand new document, all menu items Save, Save as, Save and compress as well as Open must crash the application in your case. Is it right?
Absolutely no !
In file menu
New : OK Open : Nok Open recent files : OK Save : Nok Save as : Nok Save and compress : OK
In Furniture menu Import Furniture, choose : Nok Import Furniture bib : Nok Import Texture : choose picture : Nok
Option Create photo Save : Nok
To understand better , we can write on french section.
[Edit 1 times,
last edit by bdfd at Apr 16, 2017, 6:33:04 AM]
