Re: view problem
It looks like a bug that happens from time to time in multi level homes. Please send me your file, I'll fix it.
Re: view problem
It wasnt advanced project so I made new one and save every time after changes. Problem happend when I put furnitures like windows and drag them at the edge of 2d view window. "see all levels" option doesnt help. I have sent the file to puybaret.
Re: view problem
Thanks for the file which helped me to reproduce your issue. The problem comes from the small walls you drew in some corners as shown in the following image:
As you can see, it creates some walls that may have a null length side, and a part of the program that measures the distance between an object and wall side failed for a side equal to zero. I fixed this bug and the correction will be available in the next version. Meanwhile, you should avoid these small walls and connect directly walls while drawing them.
