Total posts in this thread: 7
Previous Thread This topic has been viewed 3391 times and has 6 replies Next Thread
kubaf91
view problem
How can I set view to deafult? After moving furniture my screen went white in 2d and 3d view. Couldnt see nothing from my project
[Apr 27, 2017, 10:26:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: view problem
Perhaps a point of view too near of a wall ?
Try to update it...
Change between aerial and virtual mode...
[Apr 28, 2017, 5:40:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kubaf91
Re: view problem
Ui looks very weird after that happend looks like bugged.
https://ibb.co/e9tFy5
[Apr 28, 2017, 7:43:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: view problem
Right click and choose 'see all levels'...
[Apr 28, 2017, 8:03:16 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: view problem
It looks like a bug that happens from time to time in multi level homes.
Please send me your file, I'll fix it.
[Apr 28, 2017, 8:14:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kubaf91
Re: view problem
It wasnt advanced project so I made new one and save every time after changes. Problem happend when I put furnitures like windows and drag them at the edge of 2d view window. "see all levels" option doesnt help. I have sent the file to puybaret.
[May 4, 2017, 8:27:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: view problem
Thanks for the file which helped me to reproduce your issue. smile
The problem comes from the small walls you drew in some corners as shown in the following image:
As you can see, it creates some walls that may have a null length side, and a part of the program that measures the distance between an object and wall side failed for a side equal to zero.
I fixed this bug and the correction will be available in the next version.
Meanwhile, you should avoid these small walls and connect directly walls while drawing them.
[May 30, 2017, 6:25:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
