German
Problem with the interface or the interface of the sh3d
Hiho sorry for my english, I use the google translator.
So my next problem is when I go with the mouse over the surface and what would click to move the pictures with the mouse, and I do not know any more, I add a few left to help you understand the problem better.
I have taken the help of another post. Started contest with jre1.6.0_05 x64 including 3D view. There is a new version of the d2d changes in Java 6 (10x), DirectX and graphic card driver.
1. Download and install jre-6u5-windows-x64.exe 2. Go to Program Files / java / jre1.6.0_05 3. Copy and overwrite directories bin and lib from the java installation folder to Sweet Home 3D / jre8 directory 4. Start SH3D.
German
Re: Problem with the interface or the interface of the sh3d
Hi Puybaret, your help has unfortunately led to no result, I'm with my latain at the end.
I try to explain that again. When I start the program, and when I am working on it, it is about 5 minutes well, but then it begins to distort the surface with the mouse, and then the surfaces overlap, but is only optical, I must Then look blind with the mouse buttons.
As I said today I have even updated my graphic card an update.
You have created a great program, which also gives me pleasure to work with it.
I hope you still fall which one could possibly make, I think however I am not the only one has such a problem has.
Hi Puybaret, your help has unfortunately led to no result, I'm with my latain at the end. I try to explain that again. When I start the program, and when I am working on it, it is about 5 minutes well, but then it begins to distort the surface with the mouse, and then the surfaces overlap, but is only optical, I must Then look blind with the mouse buttons. As I said today I have even updated my graphic card an update. You have created a great program, which also gives me pleasure to work with it. I hope you still fall which one could possibly make, I think however I am not the only one has such a problem has. With kind regards Gadi
What is your OS ? RAM (installed and used => 'help' -> 'about') ? Graphic card ? Weight of your project ?
Is it the same with a new project with only 4 walls, 1 door and 3 Windows (and eventually a roof) ?
Your description did think me that the pc has a memory problem...
German
my Os is Windows 7 64 bit my Ram ist 16 gig ddr4 2133 my Graphic card is a Gforce gtx 970 asus oc strixs my Weight of your project is
So my projects are not as complex as I find, I try, for example, to form the garden of my brother after 1 to1 ifs stop, and eventuel to him also so that he may want to take some things.
I have times a video uploaded where one can see the good as I move with the mouse me and thereby everything distorted.
my Os is Windows 7 64 bit my Ram ist 16 gig ddr4 2133 my Graphic card is a Gforce gtx 970 asus oc strixs my Weight of your project is So my projects are not as complex as I find, I try, for example, to form the garden of my brother after 1 to1 ifs stop, and eventuel to him also so that he may want to take some things. I have times a video uploaded where one can see the good as I move with the mouse me and thereby everything distorted. https://www.youtube.com/watch?v=mmhYrpfETTk&feature=youtu.be
The configuration of your pc is more than correct. Except for Win7 that I find unstable... The video is clear, it's a video memory problem.
Did you have some troubles with another soft ?
Have you try to install an 'old' version of sh3d (5.0 or 4.6) with an adequate java ?
Another test : have you install an anti-virus and testing the pc lastly, an anti-malware search ?
Regards.
